Skip to content
  • There are no suggestions because the search field is empty.
How to create a customized 'Help' response for Webmail login failures
MDaemon has features to allow administrators to create a customized statement displayed to users when a login attempt fails to Webmail. This can be configured globally or per domain.
NOTE: Per domain 'Help' statements require a valid, individual host name.
To configure a global 'Help' statement:
  1. Select Setup
  2. Select Web & IM Services...
  3. Expand Webmail
  4. Select Settings
  5. Enter the customized string in the Login failure 'Help' text (can contain HTML code): text box.
To configure a per-domain 'Help' statement:
  1. Select Setup
  2. Select Domain Manager
  3. Expand the menus for the desired domain.
  4. Select Webmail
  5. Enter the per-domain statement in the Login failure 'Help' text (can contain HTML code): text box.
Watch the how-to video here:
